12v 2CH remote
27 Oct 2007
Antrim
Hi guys,
Question. I have a 12v 2 CH remote switch and key fob (see pics) but no wiring diagram and no knowledge of this type of thing, good start I know! I am wondering;
can I use this for simply remotely switching a 12v beacon on and off
and if so can anyone give me a clue on what the wiring set up is@
Any help would be greatly appreciated.
The first 6 terminals will be two sets of 3. One set for each relay. Each relay will have a common, a normally closed and a normally open. You want to use the common and normally open of one relay.
If you wire the warning light ground (black wire) to the lighter socket black wire (twist together in the screw terminal), then add a spare piece of wire from the lighter socket red wire (twist together in the screw terminal) over to the common on the relay, then wire the red of the warning light to the normally open of the relay.
