My bathroom was fitted with 3 - 12v 35w shower lights about 2 years ago. One of the lights has started to flicker/dim/extinguish. If I switch off & on again it works fine for about 1 minute & then flickers etc. Have changed the bulb for a new one & changed it with one of the other working bulbs but the same happens on the same light. This must rule out a faulty bulb. The 3 lights are all connected to one transformer, rated 105VA, does this rule out the transformer. The wiring from the transformer goes to a good light, then the faulty light then a good light. I notice that none of the fittings are earthed, even though twin & earth wiring, the earths being connected together but not connected to the fitting. Can someone help?
