Not sure if this is the right place to post this, it is vehicle related, but more to do with electrics, i want to try and repair a faulty solenoid the internal connections in the old one have failed, so it will involve rewinding the core, (its only about the size of a cotton reel) does it need to be a special wire or would any thin copper wire work It is to operate a small hydraulic valve on a tractor (only available as a complete unit at the cost of £360 hence the attempt to rebuild it) It has a 12v supply to it and then the other end of the internal coil seems to earth to the valve body (difficult to tell) Any help much appreciated
