    Dismiss Notice
12VDC Geared Motor Battery Advice
Discussion in 'Electrics UK' started by Reedswood, 8 Sep 2013.
  1. Reedswood
    Reedswood
    24 Jul 2012
    28
    Thanks Received:
    Sussex
    Country:
    I've just bought a wired Geared Motor 12VDC 8RPM which I'd like to use as part of a rotating spit set up, and wonder what would be the best battery to hook it up with and use for maximum output; I did see info on this elsewhere, but lost the link on my browser crash, so just hoping to get some advice on this to ensure I don't burn it out!
    Thanks!
  2. Sponsored Links
  3. Ian2008
    Ian2008
    10 Mar 2008
    71
    Thanks Received:
    15
    Norfolk
    Country:
    Without the rating of the motor it is not possible to help.
    what is the motor rating, it will (should) be on a plate or sticker on the motor.
    With this info we can help
    • Thanks Thanks x 1
  4. big-all
    big-all
    12 Jul 2004
    18,322
    Thanks Received:
    1,406
    Surrey
    Country:
    for example if your motor is about 1 amp/12watt will run for around 6h30-7h on a 7.2 ah battery
    you will only burn out the motor if you overload it
    12v is the engine and ah is the fuel tank
    • Thanks Thanks x 1
  5. Reedswood
    Reedswood
    24 Jul 2012
    28
    Thanks Received:
    Sussex
    Country:
    Hi, and thanks for the replies...it's this one I've got:
    [​IMG]
  6. big-all
    big-all
    12 Jul 2004
    18,322
    Thanks Received:
    1,406
    Surrey
    Country:
    you need to know the power consumption to know the battery required
    but on such a small motor a 7 ah battery would should last the average bbq length off around 4hrs but purely a guess without the power consumption figures
    • Thanks Thanks x 1
  7. JohnW2
    JohnW2
    28 Jan 2011
    43,878
    Thanks Received:
    2,772
    Buckinghamshire
    Country:
    Indeed, but whether such a tiny motor even with its gearing, would be able to turn a significantly loaded BBQ spit is, I would have thought, a less certain matter.
    Kind Regards, John
  8. big-all
    big-all
    12 Jul 2004
    18,322
    Thanks Received:
    1,406
    Surrey
    Country:
    a gearing off several hundred to 1 even several thousand to one suspect it will have the power if not the strength in the gearing
    • Thanks Thanks x 1
  9. winston1
    winston1
    11 Jan 2010
    5,935
    Thanks Received:
    436
    London
    Country:
    Very unlikely. AH capacities are quoted at the 20 hour rate, i.e. your 7.2AH bayberry would last 20 hours at 0.36A. At higher loads the capacity drops.
  10. Sponsored Links
  11. JohnW2
    JohnW2
    28 Jan 2011
    43,878
    Thanks Received:
    2,772
    Buckinghamshire
    Country:
    Gearing will not increase the power, only the torque, but you may be right. However, I definitely would not out any money on it!
    Kind Regards, John
    • Thanks Thanks x 1
  12. big-all
    big-all
    12 Jul 2004
    18,322
    Thanks Received:
    1,406
    Surrey
    Country:
    i fully agree unless it is specifically made for the purpose off rotating several kilos of badly balanced meat it will fail
  13. Jackrae
    Jackrae
    20 Nov 2012
    2,107
    Thanks Received:
    349
    Dumfriesshire
    Country:
    Plus the heat travelling up the spit shaft will melt the plastic gear wheels that model motors invariably contain
  14. mikeyd
    mikeyd
    17 Jul 2007
    783
    Thanks Received:
    75
    Country:
    You can not burn it out unless yo give it more than 12V.
    We can't say how much current or power it needs. The data plate you showed missed that important detail out.
    Post a picture, and we'll have a guess. Or have another look at the spec's and if there are any figures stating Amps or Watts, or even HP, then reply.
  15. JohnW2
    JohnW2
    28 Jan 2011
    43,878
    Thanks Received:
    2,772
    Buckinghamshire
    Country:
    I'm not so sure about that, if it grinds to a halt, under power, due to the strain of trying to rotate the hog!
    Kind Regards, John
  16. big-all
    big-all
    12 Jul 2004
    18,322
    Thanks Received:
    1,406
    Surrey
    Country:
    are you saying the battery would be far more inefficient at 1 amp ??
    i have made the assumption off 3-10% loss at 1 amp ??
  17. winston1
    winston1
    11 Jan 2010
    5,935
    Thanks Received:
    436
    London
    Country:
    Yes.
Loading...
Share This Page
