Looking for some advice please.
There is a 2G RCD socket (13A 30mA) in the ladies changing room of my son's gym (installed under previous owner) presumably to allow clients to use hair straighteners etc.
The socket appears to be working OK however when the "Test" button is pressed on the faceplate both the socket breaker and the circuit breaker (20A 30mA) on distribution board trip.
Is this normal or is the test circuit on the socket faulty?
I believe the 17ed regs allow an "ordinary" socket to be used if it is more than 3m horizontally from zone 1, and that "fixed partitions may be taken into account where these effectively limit the extent of locations containing a bath or shower".
Does this apply only to domestic premises or does it apply to commercial premises too?
The showers (with shower trays) are in stud partition cubicles (full height wall) in front of which is a partition type cubicle (of the kind typical found in the toilets of commercial premises) to provide a private drying/changing area.
What would be considered an appropriate distance from the cubicle to the socket if it wasn't RCD?
