We have just replaced the aged Potterton boiler in our house with a Worcester Bosch 30CDi System boiler.
Our house is a typical Victorian end of terrace, with three bedrooms and a bathroom in the original part of the house and two further bedrooms in a rear part of the house.
We are using the existing pipework for the radiators which is all 22mm in the main part of the house and 15mm in the rear part. There are 11 rads in the main part of the house with 5 in the rear.
The rads in the rear part of the house take far longer to warm up than those in the main part of the house and I am trying to understand what differences 15mm pipework is having over the 22mm. The heating engineer says the valves on the rads at the front can be adjusted so that the rear ones come on more quickly. But I wonder if the rear radiators are being starved of hot water.
The 15mm pipework currently tees straight off from the 22mm with no reducing pipework and since the floorboards are currently up, I am wondering whether to change the pipework from the tee to 22mm and reduce down to 15mm further along.
Can anyone explain the effect that pipe sizes have on a CH system and give any suggestions?
Thank you
Thank you
