Shear stays the same - shear capacity reducesBearing stays the same, shear increases![]()
Have a think, there is at least one more obvious one.We have only discussed 3 options so where does last come from?
Shear madnessIf it works perectly well structurally (which can be proved) and avoids the cost of hangers, why should it be a 'last resort option'?
C3How about timber fixed to the web, 100mm timber plate on top of the beam, joist hanger nailed to the timber plate
Anyone got any more options? (This could go on and on)
Oh I see - I needed to start at the beginningC3
You can't then build on top of the plate.
The design shear force due to the load stays the same, the unit shear force to be taken by the section increasesShear stays the same - shear capacity reduces![]()
The wall that the steel beam wll support already exists, therefore any lateral re-positioning of that beam is not possible, or is minimal.Why would they exclude that possibility?
Op talks of things being fitted ( future tense) hence whilst wall/beam cannot be moved joists are open to length as requiredThe wall that the steel beam wll support already exists, therefore any lateral re-positioning of that beam is not possible, or is minimal.
The wooden joists also already exist, therefore it's not possible to stretch the lower half of the joists to fit into the web of the steel beam.
The OP's post:Op talks of things being fitted ( future tense) hence whilst wall/beam cannot be moved joists are open to length as required
Hi, I'm having a 178 x 102 rsj (160 x 45 internal web) fitted to support an existing wall and want the existing joists (50 x 150mm) to be attached slightly higher than the rsj.
