Just removed the original fireplace hearth and came across this. Before I get someone in to refill the hole with concrete, I wondered if the pipe needs better protecting?
The pipe is really solid which makes me think it might be iron and not copper? Was that standard practice in those days for gas pipes running under the floor? Seemed odd at first that there was be no protection for it.
We don't plan on using the fireplace, however, it isn't obvious where the main gas line tees off for this section. The gas supply starts in the garage and then the pipe runs into the living room wall but then it is no where to be seen on the other side, which makes me think it might split off in two ways under ground somewhere?!
Just wanted to understand a) what the pipe is made of and b) does it need further protection before being covered?
Cheers
Cheers
