1way & 2way switches help needed!
14 May 2005
Surrey
yes i've done something silly- i've replaced 2 hall switches and of course something's gone wrong.
upstairs hall light switch=1 way switch works fine on and off but does not swich OFF when switched ON from downstairs.
downstairs hall light switch=2 way switch which works fine for downstairs light and for upstairs light on and off but now does not switch OFF the upstairs light when switched ON from upstairs
downstairs light shouldn't be the prob as i drew a sketch beforehand. upstairs I'm not so sure. 2 red wires i put into 'C' and the black, blue and yellow into L1.
please don't take the **** :wink: I'm trying, but got no one to teach me. sob sob. :cry:
You need to check the downstairs switch and see which of the 3 core has been used as the "common" ie red or yellow. Duplicate this upstairs then put the red from the twin and earth into L1 with one wire from the 3 core and the black from the twin and earth with the last remaining cable into L2. For clear diagrams the for reference section may help.
if i take you at your word and you say the upstairs has a one way switch that would be wrong for a start, it should be 2 way, one gang (it has 3 terminals) not 1 gang 1 way, which only has 2 terminals
yep i think that could be the prob. will try it with a new switch soon... thanks.
