Right all, thanks for taking time to look at this!
What i currently have here is a 2 gang? (i.e. 2 seperate switches in 1 box)
the one switch turns on 2 flourescent tubes down one end of the attic, the other turns on the other 2 down the opposite end!
current setup is
all 3 blacks are joined,
red feed into common, which is crossed to the other common
red feed out from L1
red feed out from L1(2nd switch)
Soooooo, i have a live cable coming in and the other 2 run off to the lights.
what i want to do is make ONE of the switches into a 2 way, the wiring is in place as is the new switch.
i tried plenty of combinations, some work but trip the switch when the lights are turned off?!
Any help would be MUCH MUCH appreciated!!!!
Thanks again!
Dave
current setup is
Thanks again!
Dave
