2 Gang Seperate Lights
29 Nov 2006
Hertfordshire
I posted a query regarding a problem with a 2 gang switch. That post seems to have dissapeared, so here is the updated problem. 2 gang switch, live into com, switch live out of L1-operates centre ceiling light-ok.
Second gang has a connecting wire from com1 to com2, switch live from L1 oprating low voltage transformer. When switching on second switch, the ceiling light comes on as well as the low voltage lights.
The low voltage supply dosen't come in contact with the ceiling light except with neutral at a junction box. :?:
Maybe you have not indentified the 'switch line' correctly in the first switch ? Just an idea.
Hope it helps.
its not disappeared - as your post count indicates - its simply moved down the forum onto page 2, if you bother to look. This is because other posts have been made since wednesday, and nobody replied to your post, which happens sometimes, its unfortunate.
Many thanks NotaSparky, I'll investigate further and let you know, at least it's constructive and not a trivial comment..I did bother, but just missed it.
dont look hard do you, took all of 3 seconds to find it, here
Doesn't take a lot to get a back up these days, does it?
my backs not up, it just tickles me how many people do not read what is infront of them
I have tried connecting the switch live which leads to the transformer only and still the main light comes on as well as the secondary lights. I have traced the switch live to the transformer which then returns to neutral. I cannot find how the power is reaching the main (1st) light. The live in the switch is a spur from the ring. :cry:
