I need to wire two ovens onto an existing 32AMP cooker circuit. The hob is gas. One oven is a combi and comes in under 13Amp with a plug, so will go on a single socket.
The problem is the other oven is maxed at 15amp so exceeds the normal fused spur capacity. Is there such a thing as a 15 or 20amp fused spur unit ? The alternate is to connect via a 20amp DP switch but them the oven flex is only protected by a 32amp breaker.
Any ideas ?
Any ideas ?
