2 PIR Floodlights from 1 Fused Spur
14 Oct 2017
Hi folks,
To save running an additional cable to the external of the house, drilling another hole through the wall etc I was wondering if it's possible and safe to run 2 different PIR Floodlights from 1 fused Spur, in essence running a junction in-line from the house via an IP rated junction box and then running this to the second floodlight?
Does such a job require Part P qualification or is it down to a 'competent' installer?
Yes.
Depending on the route, you could connect it to the first light and save having to use a junction box.
No such thing as a Part P qualification.
Part P of the Building Regulations states that you must do the work to ensure safety for those using the light.
Yes, competent will do.
