about this time last year I mentioned that my daughters bungalow had a 2 pumped central heating system and that later on in the year it developed a problem i/e water started to overflow fron the exspansion tank in the loft, and that forum readers suggested that it that it was the coil in the cylinder that had gone. Unfortunatley while I was on holiday see called out a plumber!!!! who said that the ball cock was all rusted up and that it needed changing (what a load of rubish) and he fitted a new one. The was that he showed her was a metal one and i know for a fact that the one that was there was a plastic one. And he charged her £75. and that the coil had not gone ( she told him this is what her dad thought). Any how my question now is two fold, as I want to fit a 2 port MV and should i fit it on the flow or return side of the DHW or should it be fitted on the same pipe as the flow ( not sure as to wheter the pump is on the flow or return as it is almost a year since i looked. And finally should the wiring of the mv be in series or parallel with the pump and the cyl stat.
