Can anyone advise me?
I'm removing some wiring from my garage before it's taken down and replaced with an extension. I've removed some outside lights which operate from a 2-way switch. Here's where the strange bit is that I've never seen before. The switch in the house is part of a 2 gang switch. One switch is being used as a 1-way switch, the other controlling the lights outside. However, the 2-way switch only has 1 T&E cable into it (which goes to the other switch), the actual power or COMM is taken from the adjacent 1-way switch by means of a short wire connected between the two COMMS in the switch. I can see exactly what it's doing and I can see that the Neutral for the lights is connected into the ring in a different place.
Is this safe? It just looks a bit amateurish. I'm not a professional, so I might be utterly wrong.
For those of you who want to remind me about Part P and give me a lecture, please do not respond. I know all about it and the rebuild will be done by a proper sparky. Also, to make it easier, I've not mentioned the earths which are all present and correct.
