    Dismiss Notice
2003 Vauxhall corsa 1.2 petrol won't go above 30mph
Discussion in 'Car Repairs / Maintenance' started by littlecookie, 26 May 2015.
  1. littlecookie
    littlecookie
    22 Apr 2005
    240
    Thanks Received:
    Yorkshire
    Country:
    Hi my sons 2003 corsa 1.2 petrol feels like it's running on 3 cylinders no power at all ,changed coil pack but still same new plugs too up hill is about 15mph on flat lucky if it gets up to 30mph,feels a bit splutterry too when excererating ,it's quite high mileage at but up til now been running ok ,engine warning light showing on dash too
  2. Sponsored Links
  3. gregers
    gregers
    28 Mar 2008
    6,301
    Thanks Received:
    500
    Sussex
    Country:
    then i would say its gone into limp mode.
    get the codes read either by buying a obd lead,download some software for your car and using a lappy read the fault codes on your ecu.
    or spend a fortune at the dealers.
    but the codes will need clearing.
    • Thanks Thanks x 1
  4. littlecookie
    littlecookie
    22 Apr 2005
    240
    Thanks Received:
    Yorkshire
    Country:
    Ok cheers never heard of limp mode until.now, Is there anything you can think of to check before, I take it to local garage, someone says egr valve might be clogged, not a clue myself
  5. Belle427
    Belle427
    16 Jan 2006
    2,980
    Thanks Received:
    289
    Newport, S Wales.
    Country:
    The maf sensors fail commonly on these and cause that kind of issue, you can disconnect it and generally the car should run better which proves its cream crackered.
    Its located on or near the main black plastic air filter housing, if you need help locating it post up a picture of the engine bay.
    • Thanks Thanks x 1
  6. mfarrow
    mfarrow
    2 Nov 2009
    2,126
    Thanks Received:
    244
    Warwickshire
    Country:
    Does it free Rev OK when hot up to the red line? If not could be blocked exhaust. Drop down pipe and see if it runs better.
    Also check breather pipes around the valve cover and manifold. Are they all still in good condition and attached?
    What was the condition of the plugs when you changed them?
    • Thanks Thanks x 1
  7. littlecookie
    littlecookie
    22 Apr 2005
    240
    Thanks Received:
    Yorkshire
    Country:
    will check pipes, plugs where bad, one was a bit blacker than rest
  8. Sponsored Links
  9. littlecookie
    littlecookie
    22 Apr 2005
    240
    Thanks Received:
    Yorkshire
    Country:
    Looks like engine screwed ,gunked up rattling now really bad ,cheers for help.
  10. mfarrow
    mfarrow
    2 Nov 2009
    2,126
    Thanks Received:
    244
    Warwickshire
    Country:
    These engines are a bit of a pig. The chains tend to go slack and they end up sounding like a diesel when hot.
    Mother in laws had an oil pressure issue where the pressure relief valve piston had started sticking in its bore. So low oil pressure isn't an impossibility, but it doesn't immediately explain the lack of power.
  11. littlecookie
    littlecookie
    22 Apr 2005
    240
    Thanks Received:
    Yorkshire
    Country:
    Much louder than diesel ,taken it to a garage to sort out ,engine is worn out ,has lasted over 100000 though
  12. mfarrow
    mfarrow
    2 Nov 2009
    2,126
    Thanks Received:
    244
    Warwickshire
    Country:
    Replace it with a 1.7dti/di diesel, wife's is on 176k now.
    • Thanks Thanks x 1
  13. rds60h
    rds60h
    5 Mar 2015
    28
    Thanks Received:
    3
    Bedfordshire
    Country:
    This problem is usually the Coil Pack, the EGR Valve (Exhaust Gas Recirculation) especially on the Twinport engines, the ECT Sensor (Engine Coolant Temperature) or the MAF Sensors (Mass Air Flow).
    Unfortunately all 4 of these can throw up similar fault codes and usually means having to illuminated the ones that are OK.
    Two other possibilities but rarer are a cracked exhaust manifold or the collapse of the inside of the catalytic convertor.
    **My Mk5 Astra 1.6 has just started the exact same symptoms !
  14. rds60h
    rds60h
    5 Mar 2015
    28
    Thanks Received:
    3
    Bedfordshire
    Country:
    Changed my Coil Pack this afternoon, Bingo !!
    It's running sweet as a nut.
Loading...
Share This Page
