2005 Toyota avensis ABS light.
10 Dec 2006
Sheffield
Hi i have a 2005 toyota avensis 2.0 d4d ,after recently changing the front wheel bearing noticed that the abs light on the dash stays on,is there anyway of resetting this without diagnostic tools, i have taken the sensor out a cleaned also disconnected battery for an hour in hope it would clear any help appreciated.
Its logged a fault either because the sensor was damaged when changing the bearing or the reluctor ring(if it uses one) that it picks up is not in the correct position/damaged.
It should self cancel when all is well
As above....the bearing must be put in the correct way - which isn't always obvious, especially if the reluctor magnet is held in the bearing dust seal.
Don't ask me how I found that one out :shock: :P
John :)
But, I'd contact Toyota, because there's probably a recall? Or if there isn't, its about the only thing there wasn't one on.................. :D
