Got a leak 3 feet down under crazy paving...I've dug a hole and found the connector that seems to be a 'push' fit type which has worked its way loose. What is the best way to connect lead pipe to 20mm poly pipe? Can a brass compression connector be used under ground?
Oh and before you tell me, I know I should replace the lead pipe from the road to inside the house but I haven't got that sort of cash around at the moment especially as I would want to go down the 'mole' type 'trench free' route.
