22mm compression nut with 3/4 parralel thread
SMG
31 Oct 2007
Manchester
Searched hi & lo for this compression nut, fits DHW cylinder. None at local plumbers merchants.
Compression nut which accepts a 22 mm pipe & olive, but has a 3/4" BSP thread.
The cyl has stainless steel fittings, basicly an externally threaded pipe, the inside diameter takes a 22 mm pipe & it is secured by a compression nut & olive.
If this fitting has a 3/4" compression nut, then thats what I want.
http://www.tools4trade.com/d-98726170-22mm-x-34-male-iron-straight-112d6.aspx
The book describes it as, Plumbing connections, inlet / outlet, 22mm compression fittings / 3/4 BSP Parralel thread.
Sounds like a Megaflo or Santon cylinder. You'll probably have to get them direct from Baxi or through a merchant such as City Heating Spares, they aren't a commonly-used thing away from these cylinders
It is a Santon m8, premier plus.
Found em,
Set of compression nut and olives: 95607838
Thanks guys.
Knew it, you need part number 95607838, which is a set of four nuts and olives
