22mm existing pipe or change to 15mm central heating
21 Jul 2023
Hello All,
New member here,
Im not a plumber by trade only a weekend Diy when i get the chance
Long story short, In the lounge and dining room we have some radiators they are double rads
2 x 11823 btu in the lounge
1 x 11823 btu in the dining room
the 22mm pipes enters the lounge via a 4.2m run to the first rad then another 6m run to the next rad then another 10m to the dining room rad
i believe 22mm is the correct size taking into account the length and btu size of the rads
boiler is a woscester bosch 30cdi combi boiler using a flow and return method for the ch
the concrete screed has crumbled and requires repairing so im taking this chance to replace the piping
i believe copper would be a good choice as its lasted 40 years to date
Yes copper is best, but if within a screed it must bewrapped to protect it from corrossion and any joints must be soldered, you actually get pre-coated copper a little more expensive but worth it for what you are doing
  • Thanks
Reactions: CBW
ah thats a new one on me, brilliant ill look for that now, is 22mm the correct size as above, thanks
I would keep the sizes as is , it works , you dont want to change the size and install the screed then find out down the line that you have a circulation problem
you can buy it in 25m coils so no joints to worry about, as said expensive but you will never be doing it again so do it right
  • Thanks
Reactions: CBW
