- Joined
- 23 Jun 2019
- Messages
- 35
- Reaction score
- 2
- Country
For reasons that are too longwinded to explain here, I'm going to have to get my supply pipe replaced. Currently 25mm Alkathene enters by the front door and runs approx. 10m in 15mm to the back of the house where it splits off to the taps, appliances and combi boiler.
My question is: do you think it's going to be worth paying the premium for 22mm in the replacement? The problem I am trying to solve is an apparent bottleneck happening when I'm using the shower and someone runs a tap (hot or cold) or flushes the loo, the flow on the shower dips considerably, enough to make it useless if two of these happen at the same time.
The 22 mm will run directly below the combi boiler, but the existing 15mm up to the combi will probably be harder to replace. Will I still see any benefit if the 15mm to the boiler tees off the 22mm supply first, which then goes on to taps/appliances? My logic is that one 22mm will feed two 15mm better than one 15mm will feed two 15mm.... if that makes sense. Or to I need to run 22mm all the way to the boiler to see any benefit?
All of the rest of the hot water plumbing is, and will remain, 15mm.
