25mm Olive query
29 Jan 2005
I just posted query about 25mm olives and it appeared for a minute or two and then disappeared?
I need a few 25mm olives but I can't anyone who stocks them
What would you use 25 mm olives for :?:
A good learning opportunity as I have never heard of 25 mm pipe unless it is for a mains in to a 25 mm stoptap :?
bahco
That's exactly it. I have few 25mm x22mm stop cock with 25mm olives missing.
I have replaced my dad's lead supply pipe with MPDE used a 25mmx22m stockcock. Seven Trent water connected for Nowt and if I might say they even commended me on the installation.
Now, MY brother in LAW want's me to help to do his and me being a tight so so and I would like to use one the stopcocks that I have
I've had a look on Bes plumbing but they only
do 22mm or 28 mm :cry:
Phone around all the plumber merchants, somebody is bound to do them :)
Sorry to dig up this ancient thread, but I also had the same problem. Phoned almost everywhere, and spent some time searching the net. Finally came up with a couple:
http://www.boilerrepair.gbr.cc/2120/info.php?p=4&pno=0
http://www.pulsardirect.co.uk/plumbing-supplies/addtocart.asp?ProductCatId=1000868&ProductSubId=181
Hope it's useful for someone else with the same problem. In my case I put the stopcock on *without* the plastic insert, and now want to take it off and put the insert in without buying a new stopcock. Doh!
Moderator
Sounds like Mod 10 has been tampering again.
However, perhaps he did not believe that you were really in Lithuania? I dont either!
I also think that people should post their correct locations too!
Tony
Moderator
Tony
You don't think Mod 10 has mellowed over the last 3 years Tony :lol: :lol:
