25mm or 32mm mdpe pipe.
4 Apr 2010
Humberside
For a house with 3 bathrooms. with unvented hot water. Would you take 25mm mdpe or 32mm mdpe to the house?
32mm......depends.....more info required. Pressure, flow rate, distance from main spring to mind.
its been taken from the mains in 32mm mdpe up to about 2 meters before the house I was thinking of reducing here from the boundary stop tap to bring 25mm in to the house. The water pressure is very high.
If the pressure is good I'd go for 25mm. Its going to reduce to 22mm once indoors anyway.
