We are having our CU upgraded and some cables rerouted one feed is to a small 6pitch caravan site. Currently fed by 16mm twin and earth through the house to an outside point.
The sparky has suggested we run 25mm SWA to this point instead just to keep resistance down over the length (30metre run). Is there not an alternative as it means currently running about 20metres of SWA through the house to the outside feed and then 10metres external to the junction. Seems alot of money and overkill?
He also mentioned the cable will stick out the wall exiting? Surely you drill the exit at an angle so the cable can exit the wall pointing already in the right direction and not perpendicular etc.
Thoughts appreciated!
