S
scotteng
Know of them and how they work.has anyone had any experience with voltage regulators, where the voltage is restricted within the installation to 220v, to save elec costs?
how much do they really save?
Near your consumer unit.where are they installed?
Far more than they save. You can make a DIY version using a low voltage transformer connected so that it bucks the mains voltage. However, if you know enough to DIY, you also know enough to know it won't save anything and that it's a con.what do they cost?
Nor toast taking longer to make.The manufacturers will show you how the kettle, fridge etc reduce their consumption by 17% or whatever. They don't show you the kettle taking 17% longer to boil or the fridge having a 17% greater duty cycle.
But they do get really agitated, and threaten to call security and have you ejected from the exhibition, if you persist in trying to discuss these points with them on the stand where they are flogging the things.![]()
Good point. In fact, it's actually quite a complicated situation to get one's head around if there is a transformer interspersed between the incoming supply and the installation.The other thing that never gets mentioned is their effect on LI values and the dangers of lower fault currents extending tripping times.
But if you already use dimmer switches you'll just turn the wick up a bit to get the light level you want.You can save on lights because it makes them dimmer. So does a dimmer switch and that's a lot cheaper.
We have been asked at a number of supermarkets fed from their own transformer to isolate supplies so they can lower voltages.
So their open air fridges will use less electricity
