I have moved into a new (old) house, and it has a system boiler. The water tank is next to the garage with the overflow just on a down pipe into it. There is quite a lot of run off on this and the previous owner has fudged a hose pipe onto the end and just run under the garage door.
This does cause a little issue, the drive is quite steep so you can imagine how fun our drive was on Monday when it was -6DegC!
So for my question! The outlet is 28mm copper pipe, is there anyway of adapting this to 32mm solvent weld waste pipe, so I can run it round the garage and through the wall into the gutter drain.
The only thing I think to do (apart from solder more copper on the pipe) is to attach 28mm barrier pipes with push fit fixings, but seems an expensive way of doing it (as would running copper for the full length).
Many Thanks,
Darren.
Many Thanks,
Darren.
