Adding a Valve to Existing Pipework
29 Apr 2008
Croatia
Here in Hungary they don't have valves with compression ends, only pipe thread ends. I have bought a 1" valve that I want to put in an existing run of 28mm copper pipework. The valve has 1" BSP female ends so I have bought adapters that are 1" BSP male to 28 mm end feed solder female. I don't know how to go about this job, should I screw the adapters to the valve then solder it in? Will the heat destroy the PTFE tape? If I solder the adapters to the pipework I will be unable to then screw them to the valve. Should I make 2 additional cuts in the pipework and add couplings either side of the valve so that the section of pipe with the adapter on can be rotated? :?
In the absence of your using a compression fitting in the first place (presumably you couldn't find one), the obvious solution would be to cut the 28mm nearby and use a straight compression.
How about a long screw? Not that I'm offering, I'm not like that.
There are no compression or even Yorkshire fittings available here, only end feed. I think most plumbers still use iron pipe, copper is considered a bit exotic.
