Need a 28mm - BSP swept bend
10 Dec 2008
Jersey Marine
I have a device (which provides low pressure air flow) that has a male 1" BSP thread on the end ..... this goes into a clearance hole and fastened by a 1" BSP nut.
I want to move this out so that it joins via a swept bend something less than 90 degree (70 or 80 would suffice) or 110 degree if looking at the bend angle.
I need 1" BSP parallel male thread on one end and 1" BSP parallel female on the other.
something like:
https://imgur.com/a/puIIz3d
My thought are I take a piece of 28mm copper pipe, bend to a suitable radius.
On one end solder a 28mm x 1" BSP male endfeed
https://tinyurl.com/rf8dlwa
On the other a 28mm x 1" BSP Female endfeed
https://tinyurl.com/ssgkrng
Does anybody know of a neater way ?
Needs to be copper or brass - not iron
A normal 90° elbow is too sharp, will cause air flow problems. I see they do a F to F swept bend ...... (didn't know they existed) maybe that with a Males nipple in the one end to make it M to F
