2nd power shower
4 Jan 2006
Yorkshire
Currently running one power shower in the main upstairs bathroom, the MI's that came with the pump says it can run a second shower. The MI's don't say how far away the shower can be. The second shower will be about 8m from the 1.5bar watermill pump, will the pump be able to cope with this distance or should I upgrade or add a second pump. I know pumps are generally designed to push water so If adding a second pump is the way to go are there pumps that could be fitted closer to the shower as there is no room where the 1st pump is.
Hi Big Al The loft tanks 50gallon and the hot water cylinder 140ltrs, I don't know if thats big enough to run 2 showers at the same time but I doubt that situation will happen very often.
