2x1 Baton Fixing
7 Jun 2024
Looking for advice on the best fixing of a 2x1 wooden baton onto a dot&dab wall with concrete block behind.
Appreciating the need to execute into the brickwork behind the plasterboard…can anyone recommend the best fixing to use?
Concrete screws through the batten, board, dab and into the block
If there aren't any dabs behind where you want the batten, drill holes in the plasterboard, pump enough gripfill into the hole to form a lozenge around it, bridging the gap between board and wall then drill the walll proper when it's gone off
