3 / 4 way lighting dimmer
3 May 2004
I have a lighting circuit that controls the lights by 3 switches in at various points in the hallway.
I wish to make the circuit dimmed. Is this possible?
your setup will have 2 2 way switches and a 1 way switch
you can replace one 2 way switch with a 2 way dimmer this will allow you to swtich from anywhere but only dim from one point
the other way is to buy master-slave dimers the master dimmer connects to the switch cable to the light then you just connect all the slaves with 3 and earth to the master
surely it will be 2 two way and one intermeadiate? but the master slave option will still work
