3 port valve noise
16 Sep 2004
Leeds
Hi guys
When we turn up the room thermostat the boiler does not ignite straight away, in can take upto 5-10 mins to ignite. Last night I checked the 3 port valve just after turning up the room thermostat and it was making quite a loud grating noise and the lever was moving very slowly. Could this be why the boiler is taking 5-10 mins to ignite once we call for heat? Does the boiler ignite upon a signal from the room thermostat or when the 3 port valve lever has moved to the correct position?
We have CH/HW cover but want to know if we have a definate fault before making a service call otherwise we would get charged if an engineer comes and the system is working as it should.
Thanks in advance for any advice.
Yes, when the valve moves across it makes a microswitch which starts the boiler and pump.
