HI
sorry i was wrong about the postion which i think the valve is in.
it was switch to allow the central heating on, as the pipe work got hot and the valve to in the nearest radiator got hot, but thats as far as it went, didnt get any hotter, in fact went cold, even thought the pipe work from the 3 way valve is still red hot.
i need to check tomorrow what the wiring is like in the junction box from the valve
as for the programmer it is quite old, a danfoss 103, which is just an mechanical timer, with a button on the side, with either on,off or timer, the wiring again i have no idea off, but as the whole system worked ok a few weeks back i assume its ok.
i noticed that the pump has gone from making a noise, for which i assume means its working to a very quiet dull drune.
i have bought a new pump to try tomorrow as this is the cheapest component to replace.
i apprecaite all your help and know its difficult without really seeing it all first hand
All so, which way should the pump be installed, it has a flow arrow on but which way does this go, apprantly when the one was fitted in Jan, another plumber said it was the wrong way round.
The reason i cannot replace the pump which was fitted in Jnauary under
guarentee is that the plumber who did it told me he introduced a cleaner to the system and told the then owners to call him back in 24-48hrs to drain the system down and flush out the stuff he put in, he said they never did call him back and this stuff will still be in the system and has maybe clogged or damaged the pump.He told me he could not repair free of charge as his advice was ignored, he told me to drain the system my self which i did do, but what came out was clear,,,,phew
