I have a new 32mm incoming water supply which terminates directly below where my new boiler will be located. My thoughts are that I should reduce from 32mm down to 22mm and then where I tee off for the boiler, I use a reducing tee to provide a 15mm feed for the boiler and another 15mm feed for the rest of the house. Is that the correct way to do it or should I reduce from 32mm straight down to 15mm (pressure is good)?
