Hi all,
I'm hoping to buy a fan convector heater to be fitted in my conservatory (a Myson Hi-Line) and the installation manual I've found online says that it will need a 3A fused spur for power. The fan will be wall-mounted up high. At ground level, immediately below where the fan will be fitted, is a double plug socket and halfway up the wall is a double light switch for the two lights in the conservatory. Obviously I'll need to get an electrician in to do the work, but how tricky a job is this, how long should it take and (accepting that accurate figures can't be given) what sort of ballpark figure should I exepct to be paying for the job. I live in South Wales if that's any help in terms of costing.
Many thanks for any advice you can give.
