I want to install a timed fan in existing downstairs toilet (currently no fan at all). It would appear that it is now necessary to feed this via a 3A spur.
I know this could be done by feeding the toilet lighting via a fused spur, but this would kill the lights if there was an overcurrent fault on the fan.
Due to problems accessing the wiring to the pull switch, I really do not want to have to go along the lines of a 2-gang switch to provide a switched live separate to the lighting one.
So, here's the question:
As the fire incidents (as far as I am aware) which prompted the call for fused supplies to fans involved problems with condensation on timer PCBs and hence the permanent live, could I use an unswitched fused spur inline with the permanent live. ie connected via the Live In & Live Out terminals of the spur? I suppose it is possible to connect the Switched live also via its own spur. I know this would certainly work (however messily) but would it be permissible? Do I just do away with the fuse as millions of existing installations have?
