I am fitting a shower extractor fan in a down stairs shower room. The ducting will be above ceiling in between floor joists. Sounds simple but unfortunately I need to go through a floor joist so that I can position the vent in an outside wall, missing the lead flashing of pitched roof-line. The joist are about 6-8 ft long. Where should I cut the 4" diameter hole in the length of the joist and how should I reinforce the joist where I have drilled through it. Please do not advise that this can't be done. I need to find a solution. Thanks in anticipation. Mark.
