Hi all
anyone know where I can get a 400 wide by 700 rad from, without the fins on the back, I think that its an unusual size, Stelrad have discon some time ago
Cheers
Tony
There are some pipes running behind the rad from the wash basin, don't fancy burying them in the wall. Otherewise I don't have a problem with fins, the girlfriend has some lovely ones.
purmo do a 400 wide x 720mm high single panel with convector fins, (code 720411) like other posts i don't see the relevance of the fins to the pipes, it is always the bracket that will cause the prob, the face of the fins or the back of the rad will always be off the wall due to the bracket
