40mm traps
5 Oct 2008
Yorkshire
im trying to replace a 40mm trap all the ones i can find screw onto the underside of the sink i have a piece of pipe from the sink to the trap can some one tell me what i need
thanks jj
is it like this?
for a single sink
no -just a piece of 40mm pipe comming down from the sink then a bottle trap then the pipe goes through the wall to the drain.
its been repaired once and has started leaking so i thought simple job just change it how wrong was i ?
if its leaking just change the rubber seals thats the only part that wears.
or buy an adjustable bottle trap and take the top part out and use your existing pipe in its place.
thanks that sound like it might work ! will go but one tomorrow .thanks for all your patience. jj
