plugwash said:you definately need to bond the metal section that enters the ground.
whether you should also bond the other metal section is more open to debate. It can't introduce a potential into the equipotential zone from outside but it can carry potentials arround the building (pipes are usually routed near cables in my experiance).
imo the best thing to do would be to take a single unbroken run of earth cable first to the clamp on the metal section that enters the ground then clip it along the pipe and attatch it to the rest of the metal pipework.
15' of plastic pipe containing clean water sounds like a pretty good insulator to me...plugwash said:It can't introduce a potential into the equipotential zone from outside but it can carry potentials arround the building
