    Dismiss Notice
50mm shower trap same as 40mm litres/min - that right?
Discussion in 'Plumbing and Central Heating' started by sparkyshark, 19 Jun 2020.
  1. sparkyshark
    sparkyshark
    30 Aug 2008
    223
    Thanks Received:
    3
    Country:
    Hi all,
    I've gone out and bought some 50mm waste pipe from selco earlier today to upgrade our bathroom piping. The outside diameter is 55mm (hunter branded).
    We used to have a 40mm (43mm outside diameter) pipe and a ST90CP10-70 mcAlpine shower trap. https://mcalpineplumbing.com/traps/shower-traps-accessories/st90cp10-70c-90mm-shallow-shower-trap
    Am i correct in that any of the below 50mm shower traps will just connect to the above/work?
    https://mcalpineplumbing.com/traps/...es/st90cp10-hp2c-112-90mm-hi-flow-shower-trap (those petal or slotted versions look pretty good, instead of the raised plastic)
    our showertray.
    https://www.bellabathrooms.co.uk/900-x-900-shower-tray-quadrant-low-profile-by-pearlstone.html
    Cheers,
    Sparky
    • Thanks Thanks x 1
  2. Sponsored Links
  3. sparkyshark
    sparkyshark
    30 Aug 2008
    223
    Thanks Received:
    3
    Country:
    bugger wrong title.
  4. terryplumb
    terryplumb
    8 May 2017
    6,035
    Thanks Received:
    1,256
    Country:
    None will connect directly to 50mm pipe. The outlet on the traps is for 1¹/2 inch pipe ( 40 / 43mm). No idea what your on about re ltr/ per min.
  5. sparkyshark
    sparkyshark
    30 Aug 2008
    223
    Thanks Received:
    3
    Country:
    Forget the title.
    damn! I guess you're saying that i need to reduce it by adding a 40mm reducer and then attaching it to that? I wonder why they don't do it at 50mm.
  6. terryplumb
    terryplumb
    8 May 2017
    6,035
    Thanks Received:
    1,256
    Country:
    Why do you want to use 50 mm+ waste pipe? Given that the trap outlet is 40 mm ,and perfectly adequate.
  7. sparkyshark
    sparkyshark
    30 Aug 2008
    223
    Thanks Received:
    3
    Country:
    too many women in the household (hair issues) and while the floor is up may as well upgrade, i noticed some of the neighbours at 50mm pipe, much bigger than the 40mm. I also want to divert it directly into the soil stack rather than the outside gutter/drain (which also ends up in the same place) but it will be noticeably tidier than it already is.
    Previous owners must of had a bath at some point so the joists are already cut - shame to waste those cuts...
    I'm also going to divert the current 40mm waste pipe directly into the soil pipe (that's being replaced also).
    Bought the pipe also and had to cut a 4m length down as they only had that so can't take it back now.
  8. Madrab
    Madrab
    4 Oct 2012
    8,036
    Thanks Received:
    2,274
    East Renfrewshire
    Country:
    The 50mm is the size of the water seal inside the trap, not the outlet size. Outlet is still 11/2" - 40(43)mm. You can just use a 50mm reducer to connect just after the 40mm for the trap op to the 50mm, after that short piece of 40mm it will still flow better than a continuous 40 (43)mm so it'll maximise the trap outflow. Just get the fall ok.
  9. Sponsored Links
  10. sparkyshark
    sparkyshark
    30 Aug 2008
    223
    Thanks Received:
    3
    Country:
    Great thank you Madrab :) I'll ensure the fall is good. That puts my mine at rest a little now.
  11. sparkyshark
    sparkyshark
    30 Aug 2008
    223
    Thanks Received:
    3
    Country:
    ignore
  12. denso13
    denso13
    22 Jan 2007
    5,458
    Thanks Received:
    1,106
    Country:
    Yes, but not really required. A 40mm trap with a reducer will work fine.
    • Thanks Thanks x 1
  13. sparkyshark
    sparkyshark
    30 Aug 2008
    223
    Thanks Received:
    3
    Country:
    its about the same price so for the sake of mucking about with a reducer it might be just worthwhile.
    however 2" according to a conversion is 50.8. So will it take the 55mm pipe into it?
  14. denso13
    denso13
    22 Jan 2007
    5,458
    Thanks Received:
    1,106
    Country:
    Yes, the trap has a universal/multifit connection so has a bit of leeway.
  15. sparkyshark
    sparkyshark
    30 Aug 2008
    223
    Thanks Received:
    3
    Country:
    cheers denso13 unless you can think of a reason not to - i may as well try and do it that way...
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
