60'S MARLEY TILES 60' UNDERFLOOR HEATING ASBESTOS RISK
25 Nov 2012
Gwent
HI, SOME OF OUR 60'S MARLEY TILES (UNDER CARPET) ARE CRACKED AND I WOULD LIKE TO KNOW IF. GIVEN THE ASBETOS CONTENT, THIS IS A DANGER WHEN THE TILES ARE HEATED BY THE UNDERFLOOR HEATING. THANKS IN HOPE OF A RESPONSE!
When you say cracked,how bad are they...
You could put a latex based slc over them..follow mfr guidance on prep..primer ect...
The substrate I take is concrete,so with elect ufh you may want to use an insulation board to help with the heat up time,they come in thickness from 6mm up 80-mm thick,so the thicker you can use the better.
Marley tiles....if you need to remove...PPE is essential and you need to bag seal ect and you just can't dump them in a skip,your local authority will dispose for you...
