700 enclosure on 760 tray?
10 Apr 2009
Hi all
Im installing a shower inclosure in a space between a bath and wall. The gap from the bath to the wall is about 700mm. Its on a solid concreate floor..
Now the problem is the supplier does not have an easy plumb tray for 700mm enlosures. He has offered to include an easy plumb tray which is 760mm with the 700 enclosure.
Now the question is, can i install a 700 enclosure on a 760 tray?
Most enclosures have adjustments both ways, but I'm not sure an enclosure will adjust 60mm without some form of spacing. Call the manufacturer if you can :)
What if i chip the tray into the wall? the plaster is about 15-20mm. If i chipped it on the side and back wall, could i get away with it?
