We have an extension with 75mm cavity which is currently being built. Because the outer skin has been built and the inner one is down, we can no longer use the part fill rigid foam insulation (building inspector won't let us).
What are the options in terms of full fill insulation?
Rockwool has minimum depth requirement of 100mm. We can't make the cavity that wide as its built on existing narrower foundations.
Are there any full fill materials other than mineral wool/fibreglass that will satisfy both the thermal reqs and the 75mm depth?
wall is outer brick inner aerated blocks.
