Hello guys,
Cavity wall - 100mm block/ 40 celotex/ 25 air gap / 110 reclaimed bricks
I've got three walls on an extension I'm building. You may remember three weeks ago my post about building control seeing cement between the foil and the outside skin.
A day later my car engine blew up and that set me back. Cut a long story short I used a piece of flat bar to knock a lot of the cement below the DPC line.
The end wall with the windows in, cleared out easily with little ripping of foil. Attached a piece of conduit to a hoover and sucked a lot of it out.
One of the gable walls seems okay. Not much pug was down their but the board itself is not as flush as one would like due to building the brick then the block due to a neighbours shed.
The last wall, insulation was laid flush etc but the foil got torn and so touched the outside wall. I used a large paint brush on the end of a bar to glue the flaps back down. It's not perfect so will need more work. The gaffa tape I got from
wickes as I forgot to order has started peiling off so I've bought some double strength water proof stuff to try and rectify.
The BCO talked about using mirrors to confirm the cavities were good as previously discussed. He said I could pull the inner skin down use full fill then king span on the inside to get the u value required. Best 75mm fullfill I've found was rockwall eco which is 0.32.
The celcons used were standards and are 0.15's but I'm guessing they couldnt all be reused once pulled down.
Thank you in advance guys and I appologise that this is getting old.
J
