Hi all, have a question and cant find a clear answer too in the forum
We have recently had our house dry lined throughout and now the time to put the rads back on the walls is almost here. (At last, its damn cold at this time of year)
A new boiler has just been added and tied into the existing manifolds feeding the 8mm pipes to the existing heating, new 15mm to the other new rads in the house.
Question 1: Is it possible to use a 15mm TRV with a short run of 15mm copper pipe to under the floor boards or into boxing, then use a compression or solder fitting to reduce down to the existing 8mm pipe work. I am unsure if this is a good idea or not due to possible noise etc and I have heard a lot of complaints about using 8mm reducers in TRV's due to leeks etc. Also, 15mm looks better running up to the valve.
Question 2: Fixing the rads to dry lined walls. lots of suggestions here, plywood panel behind rads, cut through the dry lining, add timber supports and fix brackets to them or use a standart methods with 100mm to 125mm No12 screws. The cavity behind the boards is around 25mm. Have been around and seen many fittings done with normal screw method, good if we decide to alter Rad positions at a later date I guess.
Any advice here would be greatly appreciated, just need to get on again with stuff now, (but in the heat I hope)
Thanks All
Thanks All
