9448 Alarm Panel problems
No as before ...enter code ( reset ) so no lights are on the panel no noise ( normal day mode ) NOW walk in front of the detector you changed ( zone 3 ) what happens ?
Hi Sparkymarka, sorry forgot to mention, the LED light on the IR Sensor comes on when movement detected and then goes off when not be 'blocked'.
Regards.
Your going to have to start isolating tampers ...open panel and start with global A/T put a link in the terminals , now try to set the alarm
Ok next step put a link between 0v and TR bottom of pcb , stretch spring ...if it's still showing ....time for a new panel
Have you tried what I said with the new battery? Power down then up and reset?
Hi Guys,
thanks for all the help (and patience). Good news, it turns out the problem was a high resistance contact on the panel's PCB mounted Anti-Tamper switch, I have temporarily shorted this out and the system now works as it should.
Regards.
