A ceiling light off a plug socket.
11 Feb 2004
I've just noticed that I have a 'chandelier' light running in the centre of my dining room that is connected into the plug ring (a spur of a plug).
Is this safe? I want to put a dimmer switch on where the current switch is... is this possible?
cheers
D
like a normal light switch does - no fuses or lights or anything (although there could be a fuse under the floorbaords for it?
it should aslo have a 3a fuse in the plug,
itsnot an ideal way of doing because the question is does the cable run up the wall and along the ceiling?
I have a horrible feeling that this light is not actually plugged in, it's just spurred.
With what size cable, I wonder?
It is a spur out of the main ring (for the plugs - i.e. of a junction box) then into a fuse spur and then into the light switch. All on the same twin and earth as the plugs.
The light is not on a plug but dirct into the mains of the main ring downstairs.
Can I put a dimmer on this??
you have a fused spur in there so it should be fine so long as the cable between the ring and the fused spur is at least 2.5mm and the fused spur is fitted with a 3A or 5A fuse
replaceing the lightswitch with a dimmer is no problem in this situation
