About garden hoses.
I've an outdoor tap - and my pressure washer requires a hose to connect it to the tap.
I've got some (old - perhaps 20+ years old) hose... with joins... This hosepipe is robust (except for at the joins) but is also heavy and difficult to coil/store. I can get my pressure washer to work with it - despite it leaking at the joins... but it is cumbersome and the leaks are undesirable.
I bought a cheap lightweight hose as a replacement (it looked a bit like this one). I found this much more convenient to coil/store... but it only lasted a day before the hose itself split and failed. This cheap hose was replaced - but the replacement didn't last any longer before it similarly split and failed.
I'd like a decent hosepipe that doesn't leak. I'd like it to last - though I'd prefer one that is easier to handle than the old-fashioned hose that is extremely stiff - especially when it's cold. I'm aware of the trick of running hot water through the hose - but this isn't convenient as I only have a cold tap outdoors.
Can anyone recommend a good quality hosepipe? Ideally I'd like ~30m of hose that can be easily coiled and stored... I'd like it to be robust - but I'd also like it to be flexible, convenient and easy to use.
Any ideas?
Any ideas?
