We moved in, in 2008, we are renting this property.
Before the Landlord put it up for rent, he tried to sell it, so every room was "brand new" when we moved in.
Problem 1
One of my delightful children has put a hole in the wall on the landing.
I'm pretty sure that every wall in this house is covered with plasterboard.
The hole is about 2cm deep and about the size of a 10p piece.
The piece of plasterboard that came away creating the hole is still attached to the wall, so if one is careful, it can be pushed back into place... However, it keeps falling out, so I would like to know which product we should use to fix it back in permanently, leaving little mess.
Now the difficult part. We have birds and reptiles in the house, the birds are at the bottom of the stairs, basically there is no door between the birds and the hole in the plasterboard - so any fumes from fixing with high VOC or other fumed materials, will end up being breathed in by my Fiance's very tiny ONE lunged birds - even cooking with a non-stick pan can kill them. (Teflon gives off invisible fumes when at high temperatures) The reptiles are in our bedroom, so there is a door between, but the door is about 20cm away from the hole, and is not a perfect fit, so again - fumes can get into the reptiles. (and tarantulas)
My Fiance has used no more nails safely in the house on various applications with no problems to the critters, would this be suitable to stick the loose piece of plasterboard back into it's hole?
Problem 2
As you come up the stairs, the wall opposite has plasterboard on it, halfway up/down the wall a visible seam has become present, it is blatantly obvious, as if the two pieces of plasterboard have expanded over time and pushed against each other making a slight apex.
Would our landlord consider this as "wear and tear" to the property that is not our fault, or do you think that we will have to repair it ourselves?
If the latter, it honestly looks as though we'll have to take the plasterboard off the wall, trim one piece to fit and put it back up and then do whatever one does to prep plasterboard for painting. However, as you know from problem 1 - we cannot use ANY product that gives off ANY fumes.
Problem 3
As you go up the stairs, the bit that goes from hallway ceiling, to the slope up the stairs? This has cracked quite badly and looks like it has sagged. Upstairs is my Son's bedroom, he has been warned NOT to go on the slope that resides in his bedroom, from the stairwell. However, I believe that he frequently stands on the bit of floor JUST BY the slope, I'm guessing that he has caused the problem downstairs?
As this is a structural fault (kind of) would WE be responsible for repair, or will the landlord be responsible?
If the former, how on Earth would we fix it?
I understand that the majority of you are DIY Experts and not Experts of what is and what is not the Landlord's Responsibility, but I might just be lucky and have someone here that knows all the ins and outs of being a Landlord, so they know what is our responsibility and what is the Landlord's.
I KNOW the hole my children have made, (both deny it *sigh*) WILL be our responsibility, but surely the other two problems will be structural repairs? (Please say yes lol)
Problem 1
Problem 2
Problem 3
